Cams for 2009 Fat Bob
A recommendation here may be more difficult than you may think.
What are you looking for, torque? or HP?, economy? sound?. Do you ride two up? How much budget do you have? You do know that there is nothing better at providing more performance than adding cu inches?
If you are looking for bank for the buck, you have to be more specific about what your bang is... many here have gone through several cams looking for the right one
Then you want something like Andrews' TW21. They close the intake much earlier than stock for much better low and mid-range, but have much more overall duration, so your bike runs better at all rpm. They eliminate the oddball EPA timing, but won't affect (or might improve) your fuel mileage. Unless your can't help twisting the throttle. But the best improvement is at the rpm where you probably spend the most time cruising.
I put on a set of V&H short shots, big sucker air cleaner and the PC-V on my 09 Fat Bob. I dont see why you would want anything faster. This bike runs like a raped ape with this set up. I didnt even have to dyno the bike it ran so good with the initial download. I wouldnt do anything to the engine unless your going to the track and trying to lower your ET's.
If you were carrying a lot of weight, adding baggage and such, a cam could be helpful. But you have 96 inches of motor under you.... keep the motor running above 3000 rpm and the pure stock bikes are a lotta fun.
Don't let the name fool you, Bobby Wood is the Guru of Harley Davidson
cams. On the left side of the page link, click on the tab Dyno Runs, you will be inundated with good info about Harley cams.
