Need battery charger?
RE: Need battery charger?
I don't buy it....my dwg sat all winter without being started more than 3 or 4 times...not to mention that I had a yamaha before that (and I have to assume that the batteries in both bikes aren't that much different), and that bike sat at one time for more than 6 months without being started. Sure...it was a little rough the first time I started it, but it did start. And my harley starts every time....even if it sits for a few weeks (which doesn't happen now that it's riding season). I will add that it is in a (relatively) warm garage, and I'm sure it would've been different if the bike was outside)
I've been told the same thing about buying a charger....and I just ignore it now. Say what you will..and I'm sure others will chime in about maintaining battery life, so on and so forth...but I see battery chargers as a waste of time and money. And worst case scenario...if the battery dies...oh well..buy another one. It aint like you're buying something really expensive. Of course that's my opinion...and my own experience. If someone can make a better argument for them, by all means...go for it.
Todd
Todd
Letting a bike set up for weeks, especially this time of year, should not require charging. A newer battery. An older battery that should be replaced will probably will need charging. When I bought my 06 dyna I was told not to allow the battery to die because it may screw up the electronics. This may be true.
The bottom line is good battery, descent weather, no need to charge. As the battery ages and sits for long it should get a trickle charge.
