HIGH IDLE PROBLEM
I HAVE A 1999 DYNA WIDE GLIDE . STOCK CARB WITH SE-BREATHER AND DYNO JET AND THUNDER JET KIT INSTALLED. PINGEL PETCOCK AND 6200 SE REV KIT . PIPES ARE V&H STRAIGHT SHOTS WITH BIG CITY THUNDER BAFFLES. MY PROBLEM IS THIS BIKE IDLES HIGH AFTER A SHORT DISTANCE RIDE OR AN ALL DAY LONG RIDE . CHANGE IN TEMPTURE DOES NOT AFFECT EITHER WAY . ONE MINUTE IT IDLES HIGH AND THE NEXT STOP ITS FINE . ANY IDEAS????????????
The (stock) CV carbs do this from what I've been told.
You can adjust the idle but you need to keep it above 800-900 rpm (check your manual) at idle or it won't get enough oil spashing thru the motor.
Mine did that till I change to a AN Big Sucker air cleaner then I adjusted the idle a bit, runs great now.
Windseeker
EVO
Jul 4, 2019 07:44 PM
