Rotors for 06 Super Glide cast oem wheels
I have an 06 Street Bob and am going to install cast oem switchblade wheels from an 06 Super Glide on it. My new wheels came without a rotor, and as I understand it my Street Bob rotors will not interchange. What is the difference in the rotors, and does anyone have a part number for the 06 Super Glide rotors. I would prefer something more interesting from the aftermarket, but will settle for stock rotors if all else fails.
Thanks,
Thanks,
http://cgi.ebay.com/ebaymotors/Harle...Q5fAccessories
Ans special floating "wave washers" from HD to attach the front rotor. They are V-Rod parts.
Hmmm ... interesting ...
I removed the front rotor from my FXDI stock 13 spoke aluminum mag wheel and reused it on the FLSTC front wheel (40-spoke) I replaced it with ... reused the same bolts ... with no ill effects apparently (so far ... knock wood) ....
I reused my rear rotor similarly ....
By the by I also reused my front caliper on the FLST fork leg ... worked like a champ ....
A little surprised by all the hand wringing about the rotor and bolts--but, maybe things have changed significantly since the 2005 model year ....
R/
'Chop
- come to think of it, there was a ring (cover or thin spacer) that went under the rotor between the mag wheel and the rotor that I did not reuse on the spoke wheel.
R/
'Chop
