question about handlebar wiring
Old Jan 13, 2010 | 08:24 PM
streetbobkid's Avatar
streetbobkid
Default question about handlebar wiring
probably a dumb question but does anyone know if the plugs on the end of handlebar controls fit through the holes on the upper triple clamp on all of the 06 and up dynas, reason i ask it because my bars are already internally wired and the hole in my street bob tree is considerably larger than the one on the low rider trees, i dont want to take it apart until i know if i have to take the plugs apart or if i can just push them through.
Any help is great if no one is sure ill just go at it but i just want to know what to expect
Old Jan 13, 2010 | 09:29 PM
Hickey's Avatar
Hickey
they do!
When I took apart my front end, unfortunately, I dismantled the plugs thinking they wouldnt fit (Without actually trying). Well, they do. Taking apart all the solder and heat shrink from my extensions was a pain.
Old Jan 13, 2010 | 10:44 PM
streetbobkid
thanks i was going to just see if the plug would fit through but its pretty cold right now, the hole just looks so much smaller and i thought i remember having them be tight in the street bob holes
Old Jan 13, 2010 | 11:34 PM
streetbobkid
has anyone changed out the trees by just removing the upper and lower tree and leaving the stem in place or is this not recomended
Old Jan 14, 2010 | 12:53 AM
Hickey's Avatar
Hickey
you remove the stem nut, adjuster star nut, and then the lower tree will slide out. the stem is attached to the lower tree. I didnt remove it for powder, just had it taped off. I'm pretty sure it takes quite a bit to remove the stem, but also very unnecessary.
Old Jan 14, 2010 | 01:51 AM
jmpancoast's Avatar
jmpancoast
The wiring connections will fit throught the hole in the tree on some Dynas, but not on others. I changed trees on my Super Glide. The plugs fit through the FXD trees fine. When I put the Low Rider trees on, I learned the hole was a different size and the plugs would not fit. I had to disassemble them.
When you remove the trees, the lower will need to slide out of the neck with the stem because the stem is pressed in the lower tree.
Old Jan 14, 2010 | 08:41 AM
SC-Longhair's Avatar
SC-Longhair
You mean the molex connectors? No. They don't fit through the trees. Only the turn signal connectors fit.
Old Jan 14, 2010 | 10:20 AM
streetbobkid
thanks that was what i was looking for i didnt think the plug would fit through low rider trees the hole just looked to small
Old Jan 14, 2010 | 10:34 AM
Hickey's Avatar
Hickey
whoops sorry, saw your sig name and assumed you were talking about the street bob. My bad!
Catfish57
Dec 26, 2013 11:50 AM
LBCutta
Jun 8, 2012 09:43 AM
huskytamer
Oct 30, 2011 08:15 AM
blueangel73
Jan 12, 2011 01:34 PM
welder
Dec 10, 2009 01:24 AM
