Triple tree removal questions
I知 getting my triple tree痴 chromed on my 07 Wide Glide and have a few questions that I知 not sure about after reading the manual. 1. Will the fork stem slide out of and back into the neck with out removing the neck bearings? 2. How do you remove the fork stem from the lower fork bracket? is it screwed in? 3. Will the chroming affect the process of re-installing the forks due to a slightly reduced diameter of the fork holes from chroming??
Thanx for any help you can offer.
The stem will slip out of the top bearing leaving it in the frame. The bottom bearing can be slid up the stem by grabbing it and pulling it up, the only part of the bearing that's press fit are the races and you won't need to mess with those. I can't help you with the rest since I have no experience with them.
At this point I would highly recommend to get the service manual, you need to know specifics on how many ounces/inches of fluid to put in fork tubes, the torque on specific bolts and the tightening sequence for the bearing adjuster for the fall away check. Good luck friend, lets see pics when it gets finished up......
I do have the manual and I'm quoting the part names as the manual calls them, and ya I always thought they were called upper and lower triple trees but I guess not in the manual. Guess I leave the stem alone and give the chromer a call about leaving it in and the reduced diameters of the fork holes. Thanx
No Dave, your dead on the money man, I have scratched my head a number of times looking at terminology in the factory manuals, and asked myself, do they mean this? Retainer = bolt, keeper = nut, washer = bushing, hugh
I'm not a chromer, so I would deffinitely ask the guy what they do as a normal practice, because lot of people don't own a hydraulic press, not sure if there is some way to protect the spindle from being chromed, like a metal sleever, but I'm sure your guy has the experience and knowledge to "get r done"
For those who can't figure how to remove the chrome stem cap off; it just unscrews! Who knew? Was trying to figure it out and accidentally did. Looked all over the internet (why I landed here) and couldn't find anything. The parts catalog and maintenance manual do not show this or describe it.
trainedkilla
09-13-2013 07:59 AM
