Tubes from top of heads to SC - Big Sucker?
Old 07-29-2006, 01:24 AM
Angry_Inch's Avatar
Angry_Inch
Angry_Inch is offline
Default Tubes from top of heads to SC - Big Sucker?
Ok, so I installed my stage 1, more on that later.
But the OEM A/C has 2 hoses from the heads into the filter area. I am guessing this is for EPA concerns? My Big Sucker did not have anything allocated to them, so I guess I'm fine?
Old 07-29-2006, 01:58 AM
SUPER01's Avatar
SUPER01
SUPER01 is offline
Default RE: Tubes from top of heads to SC - Big Sucker?
You're ok.
There are holes in the banjo bolts from the heads that lead internally into the filter area. These take the place of the hoses.
Old 07-29-2006, 10:53 AM
soup48's Avatar
soup48
soup48 is offline
The reason why they have that is because of engine blow-by, simular to the pcv valve on autos.
Old 07-29-2006, 11:47 AM
Angry_Inch's Avatar
Angry_Inch
The bolts appear to be solid?
ORIGINAL: SUPER01
You're ok.
Old 07-29-2006, 12:42 PM
SUPER01's Avatar
SUPER01
SUPER01 is offline
Going from memory....
If you look one is on the end of the threaded end and the other is below the top of the head of the bolt you should see a small hole on the side . This ends up on the inside of the AC backing plate.
Old 07-29-2006, 02:16 PM
Angry_Inch's Avatar
Angry_Inch
Cool, I will check in a few and confirm. Thanks for the lead.
wolfman5874
09-11-2016 09:21 PM
lhcstreetbob
05-20-2010 07:48 PM
dawg
09-14-2009 06:11 PM
KenM
Exhaust System Topics
07-11-2006 08:14 PM
05Fatty
04-28-2006 04:36 PM
Quick Reply: Tubes from top of heads to SC - Big Sucker?
