Anyone Runnin' the K&N Factory "Type" Filter?
KBFXDLI, you say you didn't like the K&N and went back to the paper element. Can I ask what it was you felt you didn't like? I've run K&N filters in my cars as well as my bike. I'm just taking K&N's word that they are better but honestly I've never been able to feel any difference what so ever. Any gas mileage difference is not noticeable unless you were to test them under strickly controlled conditions. But nobody drives that way. There is just to many variables that will effect mileage. About the only good that I can see is that they will last forever since you can clean them. Like I said, under dyno conditions I'm sure you will see a difference so knowing that some people will feel it's worth the cost.
I can identify with Joe with the paper element. When I had my 1200 Sportster, I did Vance & Hines Slip-ons, re-jetted the carb, and installed an SE filter. The bike was a blast to ride, and it sounded good, with solid power and torque. When I installed a K&N element in that filter with THAT combination, I hated it. It sounded horrible, and the bottom end seem to go away. The paper element seemed to have enough restriction to keep the intake noise down, and it ran a little better. You can call me crazy, but a good friend of mine has an 08 FXD and he has opted for the paper element in his S&S filter assembly with S&S pipes. He tried a better flowing element, and did not like the way it responded. I think that there are so many different combinations out there, that one size does not fit all. On my Street Bob, the components that I put together work fabulous.
I put V&H ProPipe BP's on and mounted a K&N Factory replacement filter. The bike popped and snorted. Bought a TTS, remapped the ECM and when I started it up I had the paper unit in it to try and make it less lean until I did the tune. The bike sounded quieter and the power that was there was different than I expected. I put the K&N back on and the sound is perfect and the power is very apparent in the seat of my pants when I grab a handful. No more popping and snapping either. Nice to drop a gear coming into a corner and listen to the pipes sing. Gotta love the V&H!!
I was lookin' at the RK-3910, and K&N claims a hp bump of 12.05 hp over the factory unit on the twin cam motor. Call me dull, but I like the football cover and this filter fits under it.
I'm not planning on dynoin' my bike to find out even if I get one, but if it's close to that, I should be able to feel the difference.
$150-$200 is a lot for an air filter kit, but if it gives me close to the 20% they claim on their dyno sheet, that's pretty cheap for that kinda bump.
Anybody tried it? Did ya notice a difference?
It appears that the RK-3910 will stick out farther than your stock unit, due to the velocity stack that is added to this unit. It looks like it is pushed away to gain the clearance for airflow that is designed for it. If it was me, I would buy the Screamin' Eagle piece for your year, install a K&N element if you so desire, and put your cover of choice on it. The contour built in to the SE piece basically does the same thing. I have never looked at any air filter as a way to make more power, just allow the engine to do its job more efficiently, which in turn, will obviously make more power, just not power that you can feel.
dchoran
06-03-2006 12:09 AM
