Question about brakes...
I'll admit I don't know THAT much about the mechanical side of bikes, other than the electrical side... I have a '93 wide glide and the brakes are giving me a bit of a problem. What would cause BOTH front and back breaks to not release? (I can still move the bike, but I can also feel and see the brakes rubbing the rotor). I have dis-assembled and reassembled both front and back calipers and every thing is clean and works smoothly, but when they're back on the bike, they just seem to stick and not retract at all. Surely both calipers can't be bad? Am I missing something?
Practicing Brake Pad/Caliper Maintance
Go to my site and loosely follow the instructions and R&R your calipers and clean them out. Your brake fluid should also be changed every year. I have been telling members to clean out your sintered brake pad equipped calipers every 2,500 miles as prescribed and blow out the dust on organic brake pad equipped calipers every 2,500 miles. I have said this so much and heard so many arguments I will say: do what you like. You can always run without brakes if you do not clean them. This is a caliper with 7,500 miles on it below. If you would have practiced proper motorcycle maintenance your brakes will still work properly, your brake pads would not be worn down as much as they are now from possible contact with rotors and the real possibility of warping your rotors. If this is advice sounds like something you wish to take you may find instructions on my DIY pages.
