Total Newb Peg Problem
Old Sep 5, 2010 | 05:38 PM
truthfire's Avatar
truthfire
Default Total Newb Peg Problem
I have forward controls on my 2000 new-to-me Dyna FXD. The pegs didn't really allow a lot of room for my big hoofs, so I got some mini-footboards. I went to mount them today, and found quickly that because of the angle in which the boards are mounted, there is no room for my foot to get under the shifter. The boards do not have adjusters so that I can change the horizontal angle. They sit at about a strong 45 degree angle.
I thought about just moving my mid-pegs to the front, and then mounting the boards there, but I would have the same issue, as the mid-peg mounts also cause about a forty-five degree angle to occur. What am I missing? Is there some type of bracket that goes between the peg mount and the boards or pegs that would allow a change in the horizontal angle?
I feel totally dumb...
Old Sep 5, 2010 | 08:20 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
On the shifter is a bolt that pinches the shift lever to the shaft, loosen/remove the bolt and adjust the lever on the splines as you see fit.
SC-Longhair's Avatar
SC-Longhair
Have you adjusted your shifter to allow more clearance?
HD32141
Feb 9, 2015 06:19 PM
bulldog896
Feb 16, 2013 12:16 AM
gibby122
Sep 11, 2009 06:27 AM
PraySilence
Apr 10, 2009 04:24 PM
Bat
Jun 1, 2008 07:36 AM
