2008 Fxdb Conversion kits?
Old 10-15-2010, 03:25 AM
TommyGunz414's Avatar
TommyGunz414
TommyGunz414 is offline
Default 2008 Fxdb Conversion kits?
I am currently looking at Heartland Usa kits and shotgun shocks? any one have any experiance with these products and is it worth the extra buck..? new to modifying bikes looking for insight from people with experiance?
Thanks in advance
Old 10-15-2010, 06:32 AM
Roguepup's Avatar
Roguepup
Roguepup is offline
Maybe it's me but I looked up those websites and they seem all related to softtails.
Old 10-15-2010, 07:46 AM
TommyGunz414
yeap after reading into it more I think you are correct my friend.. hahah now back to square one..
Old 10-15-2010, 07:51 AM
toastman's Avatar
toastman
toastman is offline
what do you want to do to your bike?
you want lower and sleeker?
shave and fill the rear fender (fill pass. seat mounting holes, taillight hole, and license plate mounting holes) so you have a smooth rear fender, run a side mounted taillight/license plate combo and slam it down with some 11" shocks.
done and done.
Old 10-15-2010, 09:57 AM
TommyGunz414
well for starters im looking to lower the rear end and move up to a 200 or 240 change to side mount plate and lights and shave down the back fender and go with better shocks.. ad a sissy bar for looks and maybe a detatchable passenger seat for the wife to ride with for starts..then move onto exhaust and maybe the front end
Old 10-15-2010, 10:25 AM
toastman's Avatar
toastman
toastman is offline
11" shocks will drop you down nicely.
a 200 can fit without mods, 240 will require a wider swingarm, and i can't even guess as to what else.
Old 10-15-2010, 10:48 AM
TommyGunz414
aight thanks alot for your insight..
Old 10-15-2010, 10:55 AM
bikertrashchad's Avatar
bikertrashchad
bikertrashchad is offline
I did Progressive shocks and a 180 rear tire. 200 will fit, but you will have to remove your turn signals (https://www.hdforums.com/forum/membe...ore-paint.html).
Old 10-15-2010, 11:06 AM
bigdaddy33's Avatar
bigdaddy33
bigdaddy33 is offline
Look at dmcustoms.net
Now direct experience with them, but they've been around for a while and have a wide tire kit for dynas if that's what you're interested in.
Old 10-15-2010, 11:10 AM
bigmikaele's Avatar
bigmikaele
bigmikaele is offline
a 200 will fit without any mods (after you move the turn signals - that is what I have on mine) but a 240 will require a new swing arm and you will have to get rid of the struts as well. May limit your ability to have any 2-up riding without SERIOUS mods.
Quick Reply: 2008 Fxdb Conversion kits?
