The harley Cough
Old Jan 17, 2011 | 09:48 AM
bahamaharley's Avatar
bahamaharley
Stage IV
Default The harley Cough
Hi everyone, looking to solve my 1995 low rider cough.
Is this carb related, or coil related? I have cleaned my carb and I am thinking to replace my coils because they may be breaking down and causing a miss firing.
Any sugestions?
Old Jan 17, 2011 | 09:52 AM
jimsflh's Avatar
jimsflh
Battery Cables tight on both ends? have you torn down the carb and made sure the diaphram is intact (no tears or pinholes?)
Old Jan 17, 2011 | 10:21 AM
jaxdwg's Avatar
jaxdwg
Any sugestions?
Pull the top of the cv carb and put 2 #4 washers under the needle, problem solved. the problem is the lean condition when light throttle is applied, raising the needle will richen the light throttle condition but won't hurt the mileage much if at all.
Old Jan 17, 2011 | 10:25 AM
bahamaharley
Stage IV
Battery cables are tight, I have only pulled the carb and cleaned the float chamber. I did not pull the slide from the top. Thanks I will check the diapham.
Old Jan 17, 2011 | 10:33 AM
bahamaharley
Stage IV
Thanks, I will try the #4 washers
Old Jan 17, 2011 | 12:00 PM
Zig Zag 2010's Avatar
Zig Zag 2010
Old Jan 17, 2011 | 01:34 PM
perki48's Avatar
perki48
I agree with most other responses, Its most likely a lean condition. Either caused by jetting or manifold leak. Check for a leak around manifold before messing with anything else. Carb cleaner sprayed around manifold works well. If there is a leak your engine will either speed up or slow down.
Old Jan 17, 2011 | 02:28 PM
bahamaharley
Stage IV
Thanks, should I change the main jet or what if it's not a manifold leak and if so how much of an increase?
Old Jan 17, 2011 | 04:58 PM
bikerlaw's Avatar
bikerlaw
Slow down. First check for leaks. Before you start changing jets, tell us about the bike. Is it bone stock or has it been modified with pipes and an air cleaner assembly? If its been modified then probably its had the jets changed already.
Old Jan 17, 2011 | 09:54 PM
parts eeter's Avatar
parts eeter
Lean pilot jet, go up 2 sizes.
