HD Floating Rotors?
Old Jan 29, 2011 | 04:16 PM
cmvsm's Avatar
cmvsm
Default HD Floating Rotors?
Seems that the HD floating rotors are not true floaters, as they are indeed a two piece design, but are bolted together and offers zero movement between the two. So I'm not sure why this is considered a floater, if the two pieces cannot move independently of each other? I have the Thunderstar version of the rotors, and can verify this.
So that begs the question, why would I need to pay more for a two piece set that is bolted together to make one piece, versus just buying a one piece in the first place? Especially with the bolted two piece is 50% more in cost than the one. Sure, it gives HD the ability to offer more choices, as they just change out the center piece, but what mechanical advantage is it really providing? I was thinking of perhaps the heat dissipation because of the raised buttons, but would that only apply to those that are braking constantly and braking hard? Not the typical cruiser types.
Of course, there are true two piece floating rotors that do move independently of each other, its just that the HD version is not it.
Old Jan 29, 2011 | 06:03 PM
Fridge's Avatar
Fridge
They are semi floating rotors, like any OE floating disc. I've not really looked closely at mine but would expect them to be held together with a rivet and a spring?
Fully floating rotors are generally reserved for race/track bikes due to the noise generated by movement of the rotors against the carriers.
Old Jan 29, 2011 | 07:13 PM
cmvsm's Avatar
cmvsm
Would you say that the additional cost for floating rotors are worth it for typical cruising tupe of riding?
Old Jan 30, 2011 | 12:21 AM
shiftace's Avatar
shiftace
let h-d sit on those overpriced rotors. check these guys out if you want to upgrade to floaters (or semi floaters to be technical). These Alth rotors are sweet for 1/2 the moco's price. Put em on my dx and have absolutely no complaints.
http://www.oncycles.com/browse.asp?d...egory=b_rotors
Old Jan 30, 2011 | 03:24 AM
Fridge's Avatar
Fridge
Hmm, to be honest, I ride pretty hard a lot of the time but never had any issues with the solid discs.
I always swapped to braided lines and heavily sintered pads and apart from my discs bluing didn't have any issues. They were's as good as the PM 6 pots on my RK but they would stop me in a hurry when needed.
With my current ride I have only just swapped to braided lines and I've not swapped the pads out yet so can't really compared the two. I'm hoping that they will deal with the heat better so less bluing and less chance of warping I hope.
Semi floating rotors are pretty much stock across the motorcycle industry from cruisers to superbikes so the manufacturers must feel they are worthwhile, after all it's not an item they can expect to sell many of, for most people the brake discs will last for years.
Whats the cost of the newer rotors then?
Old Jan 30, 2011 | 01:22 PM
thealaskan's Avatar
thealaskan
Braking brand 13" Wave Rotors, made in Italy, spendy, around $400 if you can find them.
Old Jan 30, 2011 | 04:19 PM
grbrown's Avatar
grbrown
Floating rotors separate the braking surface from the hub, to help isolate heat build-up getting to the wheel bearings. Great for racers, OK for us. I have them all round on my Glide, Harley rear, Harrison 13" up front. They seem to work OK for me!
Old Feb 7, 2011 | 11:36 PM
cmvsm's Avatar
cmvsm
These look great. Found a place that has them for $265 each shipped. Do you know if there would be any issues using this rotor with the Harley stock caliper?
Thanks again.
REW13
Jul 5, 2019 02:46 PM
paud
May 6, 2013 04:47 AM
MoChrome
Oct 21, 2012 11:04 AM
Lowside
Jul 27, 2010 01:22 PM
docsouce
Dec 8, 2006 11:50 PM
