Stage 1 Question
Old May 18, 2011 | 12:34 AM
RebelGlide's Avatar
RebelGlide
Default Stage 1 Question
I recently installed a screaming eage stage 1 ventilator AC, vance and hines straight shot slip ons, and vance and hines fuel pack. I have noticed sometimes i get some poping on decel. Doesn't happen all the time seems like certain RPM's make it do it. Just wondering if its the pipes or if I have a lean condition. Thanks for any suggestions.
Old May 18, 2011 | 01:33 AM
Foxster's Avatar
Foxster
There's a big downside to the fuelpak - it doesn't eliminate the O2 sensors. This means the bike will try to drag the AFR back to stock (lean) in the closed loop area (cruising & low RPM).
I'd suggest fitting some Xieds to pull down the AFR in the closed loop area.
Old May 18, 2011 | 11:11 AM
RebelGlide's Avatar
RebelGlide
strange thing is i notice it worse at higher RPM's when I am twisting on it.
Old May 18, 2011 | 12:13 PM
SuperglideKen's Avatar
SuperglideKen
I would also retourque the exhaust bolts. Mine had a little popping the other day and I retorqued them and no more popping. They were real loose also!
Old May 18, 2011 | 12:22 PM
DSnoopy's Avatar
DSnoopy
I have been told that is very common for V&H shots. I have had mine Dyno's twice and I still get them on decel. I do not worry about it.
Old May 18, 2011 | 01:29 PM
2XNightTrain's Avatar
2XNightTrain
Fuelpak is your issue. PCV is what you need.
Old May 19, 2011 | 09:17 AM
ozfree1979's Avatar
ozfree1979
6th Gear
Popping adds character, haha. It's a hawg. Run it. I've got stage 1 with no fuel management and no issues. I personally think you could have skipped the fuel pack and spent that $$ elsewhere based on my experience with my machine.
At any rate its nothing major. Ride it like you stole it!
Old May 19, 2011 | 11:04 AM
RebelGlide's Avatar
RebelGlide
i got a deal on the fuel pak and slip ons together. Plan to get a pc at some point just doing it cheaply for now.
Old May 19, 2011 | 11:39 AM
ozfree1979's Avatar
ozfree1979
6th Gear
Cool bober! Nice lookin ride btw! Enjoy it
Old May 22, 2011 | 06:43 AM
LarryLives's Avatar
LarryLives
Hey OZ Can you tell me, you did pipes and air filer, but no programming or fuel change? how does it run compared to before? I have V&H pipes on my 06 WG and wanna do a airfilter but not the fuel change yet.
Let me know. (BTW From Ct as well)
((sorry to thread jack a little )
