If my Power Commander is premapped ....
Going with the Rush slip-ons, SE A/C. Going to order the PC5 direct from Dynojet with the correct map installed. Will the bike run fine by just installing the stuff, or will a dyno run be necessary? Not taking the bike to the dragstrip, just looking for improvement in running.
Go with FuelMoto. You'll get a better map, more choices of maps for future use, and excellent tech support over the phone. Prices are good, too.
You might also want to consider the Power Vision, as mentioned above, or add the Auto Tune to the PC-V.
http://www.fuelmotousa.com/
Call and talk to them about what you have and what you want. They'll take care of you. They're also a hdforums sponsor, so be sure and tell them that you heard about them here.
Having said that, if you want the best performance out of your bike then you will want a dyno tune. The map loaded on the Power Commander is not for your bike. It's a map created while another bike with similar mods was tuned on a dyno. So it will be close, but not perfect.
