Changed oil seal on front forks - questions
2006 Low Rider FXDLI
1. Anyone know the socket size on the top caps of the fork? I used a cresent wrench to get them off and on but now I'd prefer to torque to spec.
2. The oil I drained was yellow/green I have no clue what was put in by the indy originally... the new oil is red HD brand E fluid. All good or a problem?
3. The bottom bolt (on very bottom of lower fork leg) doesn't torque it keeps turning and turning (with good amount of force) but is pretty tight, problem?
I bought one o them short 1 3/8 sockets off of ebay for the fork caps, even had an o -ring to protect the finish but it was so shallow you could`nt keep it on the cap. well made but did`nt work well for me, it was designed so you could take the caps off without removing the bars.
much easier to just remove the bars and use a standard socket
