Front end wobble gone thank you everyone!!!
As for the fork oil, save up for the Ricor Intiminators and just order their suggested Amsoil fork oil from them then. I did and I like it.
I adjusted the fork bearing fall away till it was in spec and then tightened it about an 1/8th of a turn . See service manual for how to do this.
I dont know about the newer dynas since I have just gotten mine. I had 2 older dyna's ; a superglide and a lowrider. On both of those bikes I carried a wrench with me or just made sure the fork nut was tight when it started feeling loosey - goosey and it always handled much better.
It does not take much of an adjustment on the fork nut. I would just ride it and tighten it till it did not shimmy or wobble. You don't want to crank on it too much because if you get it too tight it can make your fork bearings wear out to fast.
Also make sure your tires are in spec 30 PSI in front and 40 PSI rear. (on 2011 dyna yours may be different check owners manual) . that also helped . Better front end springs or the intiminator will help lots too from all the posts I have recieved about it.
Its next on my list too.
I'm having some major front end issues too. Stock was way too soft, so I tried the SE race oil, and it was basically a rigid in front! I'm running some 20wt right now, and it's still too stiff. Sigh.... I should have listened from the get-go and got the ricors...next on my list now...
