Run, Brake, Turn Signal Module Kit
Reviving an old thread rather than posting a new one, has anyone else had issues with their HD unit? Mine isn't but 2 months old, and worked fine at first, but I had a turn signal bulb go out, (or so I thought) so I put in a known-good bulb, but still doesn't light up AT ALL. Pulled the light module out, and lights are back to stock, and working perfectly. I'm assuming the unit shorted out, and finding it safe to assume HD doesn't warranty electrical items, so if I crack the case open, is there anything inside I can replace? A capacitor, resistor, whatever? I have HD P/N 69462-06C
Look at the kits from Custom Dynamics. I'm running the RBT clusters, module, and load equalizer. They do a fantastic job. Unbelievably bright.
http://www.customdynamics.com/harley...gnal_retro.htm
I added the Harley conversion kit to my Road King. I also added a LED light kit to my tourpak. I've got this thing about having to be seen from behind at all times. To many riders been run over with the excuse "I never saw him"! I still keep eyes in the back of my head, but at least now I've done all I could to be seen.
I had the Harley version turn/brake module on my last bike, they run half voltage to make the turn signals as running lights. When I brake, it made no difference, my buddy didn't see me braking during the day, not a good idea. Bt400 tailstopper is much better, highly recommended.
http://www.youtube.com/watch?v=EV2KD...e_gdata_player
The warranty on Biketronics stuff is not 3 years, it is a lifetime warranty. If you buy from them you also have a 30 trial period which also covers return shipping. I also had an issue
with the brake light function and they had to install a resistor so it would work right. No charge for that either.
