30t rear trans + 70t rear sprocket on 07 bob... PLS ADVISE.
Old 02-05-2013, 05:12 PM
SteveO-ll's Avatar
SteveO-ll
SteveO-ll is offline
Originally Posted by JRK5892
i run the 30/70 it is a great set up for playing around as well as distance ride... i love mine
I concur....
Old 02-05-2013, 06:27 PM
vdop's Avatar
vdop
vdop is offline
X3. Love mine. Makes the bike come out of the hole a lot stronger and still has plenty of gear on the highway. Actually makes it a lot more rideable on the highway, puts it in the powerband. Still has enough gear to do over 150 mph at 6500. I would have geared it even more if it was easier with a belt.
Old 02-05-2013, 06:38 PM
McGinnes_john's Avatar
McGinnes_john
McGinnes_john is offline
Quick question to throw in-possibly stupid:
Would this set up on an already high torque motor cause problems with the crankshaft slipping on non-welded flywheels? Or is it not a factor at all?
Old 02-05-2013, 11:50 PM
HYPR's Avatar
HYPR
HYPR is offline
Make that x4. Prior to the change to the 30T 6th was pretty limited below 70 MPH. After I can cruise at 60 in 6th comfortably. I should say that at the same time I installed Dave Mackie 575L cams, Bassani Road Rage II and SEPRT. pulling wheels is a simply clutch drop at 1500 and a smoke show is simply opening the throttle quick. The ride and cruising is superb.
Bob
Crashone
EVO
27
04-21-2019 09:49 PM
deadhawg
12-02-2017 01:11 PM
Streetbob92
04-15-2016 07:49 PM
solorider75
02-04-2015 03:14 PM
jackinthebox
08-15-2009 10:25 AM
Quick Reply: 30t rear trans + 70t rear sprocket on 07 bob... PLS ADVISE.
