Headstock Fork noise while stopping
I'm thinking I might have some head bearing problems, I know there has been posts about this previous but couldn't find them. When I come to a stop it feels like there might be a little play in the triple tree head stock area, almost feels like a chattering feel. New bearings? Adjustment to something? Any help would be great. O it's a '07 Street Bob. Cheers.
No, that would be a good start, I also have read that a new crush washer is probably in order, I will grab one from the stealership, and wait for the snow to melt, the bike is tucked away for the winter in the back shop........April can't get here fast enough!
You can tighten it up without taking the upper tree off. I was able to anyway.
Just take the cap off the top nut. Loosen the top nut and then tighten the star nut under the top tree, lil bit at a time, until the fall away is set properly. Then just retorque the top nut back on and put the cap back on and you are done.
P.S. - I did all this with the front end of the bike off the ground. Just get it up enough where all the weight is off the frontend. Give the bottom of front tire like an inch or less of clearance.
