Idle Adjustment??
Old Dec 20, 2006 | 12:09 PM
Babe's Avatar
Babe
Default Idle Adjustment??
I've just finished my winter mods including the installation of V&H BSS, Scramjet AF, and PC III USB, however, the tickover is running high, at 1000 RPM, the service manual states that this can only be changed in the ECM. Is this true - meaning a trip to the stealers - or can it be done in the PC, and, if so, how?
Old Dec 20, 2006 | 12:12 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: Idle Adjustment??
1000 rpm is normal idle setting........
And yes, it must be set THROUGH the ECM.......
Old Dec 20, 2006 | 12:27 PM
Babe's Avatar
Babe
Cheers Bob,
All I need now is for the weather here to get somewhere above 32 degF, and I can give it a decent test run!
Old Dec 20, 2006 | 04:22 PM
Z's Avatar
Z
Don't know if HD resolved the low speed oiling problem to the cams on the TC, but I do know that it's bad juju to run the idle lower than the factory setting (I think 1,000 Rs) on 1340 Evo motors.
Z
Old Dec 21, 2006 | 06:30 AM
stbob's Avatar
stbob
1000 rpm good Below 1000 badd
HOGILAC
Feb 7, 2014 07:47 AM
A-Bit-Foe
Nov 1, 2010 10:37 PM
irishviking
Aug 19, 2008 03:48 PM
08HD
Apr 25, 2008 09:00 PM
crackercap
Feb 18, 2008 05:45 PM
