The "Under the ECM" method may work on an '05 and back, but with a newer 09-up Street Bob with the OEM run/brake/signal module....it aint happening with a PCIII or FuelMoto Tuner.....best way to mount the PCIII/FuelMoto tuner is exactly how Rainmkr did it, put some dielectric grease in the connectors to keep them dry and you will be fine...........If you have a PCV or FuelPak (POS) they fit fine under the seat......Ive had all of these tuners, so I know
I have had them all too, that is why I don't anymore and have the ThunderMax
mine looks like a black Power Vision box on the shelf in the garage. hooked it up, flashed ECM with new map, put it back in the box and started riding!!
I have tried to enrichen it with the closed loop bias tables, but in the end i always seem to go back to this map--seems to run the best for me ...so far. Have used this for the past two years and like the seat of the pants feel. I made these changes based on reading through what seemed like thousands of posts on the subject, and cant recall the specific reasons at this point. However, i just replaced my stock baffles with VH quiet baffles, and will be starting all over again with smart tunes this spring.
You may already know this, but I think the late SESPT tunes to 14.7 regardless of what you tell it. There are work arounds documented in several threads.
Not in my experience. I have several dyno tuning sessions that I've done on my Fat Bob with AFR readings and the only time I've ever read close to 14.7 was at the beginning when it was untouched and even then that was only in closed loop, it was much richer in open loop, ~12.3 to 13.2.
Once tuned I didn't have a single reading near 14.7, even in closed loop.
I should have mentioned that the smart tune feature of SEPST will often ignor your input (as been noticed by dozens of dyno operators). I also need to stop fat fingering SEPST into SESPT, but "late" is after the addition of smart tune.
