lOWERING FRONT
Z
As for Race Tech, your dealer doesn't have a clue. I installed them on my '97 WG, and my '06 SG. Easy to install, they just drop in, and then modify the damper tube a little. Easy work, and makes a huge improvement.
What parts, seals, bushings, etc, should I have on hand if I want
to disassemble the fork assembly on my 06 SuperGlide??
Considering some changes, and I would appreciate any enlightenment you can offer.
mud
I lowered my front forks 1" to match the similar lowering I did in the rear. I like it.
Z
You will need two "special" tools. First, in the bottom of the fork there's an allen bolt that holds the damper tube in place. The service manual says it's a 6mm. But it's not. It's a lot larger, like12mm (can't remember exactly). You won't be able to find a long enough allen socket to reach in there. Buy a standard allenwrench and matching socket, and cut the allen wrench to the proper length. Then put it inthe socket. You want to use an impact wrench on this.
Second, you'll need someting to drive the bushing and seal into place. You can buy a special tool, but it's expensive. I made one from muffler pipe I had lying around. I hear PVC tubing works good, too.
I purchased the Race Tech kit from Zanotti Motors. I used Chrome Cash and got it for free. I bought a kit for a V-Rod. The kit includes a spacer to lower the bike an inch. I didn't use it, because I wanted it lowered only 1/2-3/4" to match the rear shocks.
You cannot lower the front simply by cutting the upper spacer. All that does is decrease spring pre load. You have to put a spacer deep in the bowels of the fork.
The Race Tech kit made a huge improvement over stock. Best thing you could do for your bike. Rides like a performance machine - smooth and accurate. No nose dive on braking. No hobby-horse action when running through the gears. I just dropped the valves in as delivered from the factory.
While I had it apart, I also drilled and tapped the bottom rear of the fork for a pipe plug. Now I can change fluid without removing the forks from the triple tree.
The easiest way to lower the front is to simply slide the fork tube up in the triple trees. It's free, and doesn't take long to do. If you lower it too much - or not enough - it's easy to change.
The only part you need on hand is new seals. Cheap and easy.
…………………………………………†¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦â€¦.
"service manual says it's a 6mm. But it's not. It's a lot larger, like 12mm "
Yeah, my service manual says 12mm.
"You want to use an impact wrench on this."
I think I remember a lot of spin forever unless you impact it.
"drilled and tapped the bottom rear of the fork "
Good point.
“Race Tech kit from Zanotti - - bought a kit for a V-Rodâ€
“Race Tech kit made a huge improvement over stockâ€
why the V-Rod kit?? (superior performance level??)
(from another thread) “Race Tech gold valves and springs.
That will make a huge improvement in ride quality and handeling.
Even dropping the valves under the stock springs will make a huge improvement.â€
(last sentence) By this do you mean RTvalve/stockspring??
How much pressure is the spring gonna have coming apart?? Danger??
I have picked up a set of vRod sliders
(only diff from dyna, that I see, is length, about an inch shorter overall),
and I am going to attempt to verify which parts and pieces I will need
to mix and match, before I order the rotor/caliper/masterclinder/etcetc.
Exploded image below.
16-21 are common part #s, and a few others are as well.
mud
