Smart Tune
Smart Tune does not tune the AFRs to a specific value. Rather it is used to correct the VE tables to match the actual VE performance of your engine. If your VEs are accurate then you can go to the AFR table and enter the desired AFR and that is what you should get.
Remember when I said this? When in Smarttune mode a special map is uploaded to the ECM that among other things changes all the AFR cells to 14.7. This allows the narrow band (switching) O2 sensors to collect data across the entire AFR Range. SmartTuning is not trying to tune specific AFR cells to say 13.5. Rather It is correcting my VE so that I can enter 13.5 in a specific cell and the ECM will have an accurate base of information to adjust the pulse width to produce 13.5 where desired.
You may be limited with the power vision, but the SEPST has no such limitation with the Narrow Band O2 sensors because in SmartTune they are working well within their range.
We just set the areas of the AFR map to 14.6 first so the LogTuner knows to collect data for that cell to make corrections to the VE's. We can run full open-loop as well. There is no limitation on the Powervision.
These tuners all do the same thing. We are just confusing eachother.
However, the stock O2 sensor is actual limitation. Just because you can gather data across the entire rpm range does not mean the stock O2 sensor is giving you reliable information on anything too far away from stoich values. That is why they are called "Narrow-band" sensors. To tune the "entire" rpm range the correct way, you need a Wide Band O2 sensor, just like on the dyno. I would love to see a shop that tunes bikes on the dyno with only a stock O2 sensor. HAHA!
As for " I would love to see a shop that tunes bikes on the dyno with only a stock O2 sensor. HAHA!" ...they wouldn't use any wideband sensor fitted to a bike either, they would use an up-the-pipe sensors the same they would on any bike, so whether there are narrowband or wideband sensors fitted you would get the same tune.
The only advantage to wideband sensors is that they can keep the tune more accurate in open loop as well as closed loop. Big deal. If you got the bike tuned on a dyno or you had a good canned map plus did a good job of the auto tune to bed it in then its not going anywhere.
Instead of me trying to explain it to you, I will enlist the help of this Autometer article. http://www.autometer.com/tech_faq_an...x?sid=1&qid=48
Please call any reputable tuner you like, that tunes cars, trucks, or bikes, and ask them which type of O2 sensor they are using to tune with. I guarantee you they are using a Wideband sensor, whether they shove it up your tailpipe or replace your stock O2s.
Also, you don't know the difference between Open Loop or Closed Loop either. When the car, truck, or bike goes into Open Loop, it is no longer using any O2 sensor input, it is using the A/F table directly. When the bike goes back to Closed Loop, it will then start using the O2 sensor and keep switching/correcting based on the values set in the A/F table.
My whole point for even replying in the first place was because someone tried to say the Powervision was limited in ability, when that just isn't true. It does the same **** as an SEPST, TTS, etc. Please read that article and then reread my earlier posts and you will understand what I was saying.
Also, this stuff is just basic knowledge of tuning too. My 600HP Cobra would not still be living on the same dynotune since 2004 if it were tuned using the stock O2 sensors. It would have blown up long ago!!!
Are you sure that you know the difference between tuning a bike and smart/auto "tuning"?
Yes, you tune with a wideband sensor - obviously. However, once you have done that there is little advantage in having a wideband over a narrowband sensor on the bike to keep things in trim and you can do auto/smart tune with a narrowband sensor setup.
You tried getting at me sideways and I was just backing up what I was saying. Not trying to beef with ya!
I just don't want some dude reading this thread, with a freshly built 107 motor, thinking he can just "autotune" his way to a perfectly safe WOT tune using only the stock O2 sensors. It just is not gonna happen.
You do appear to be confused about how the narrow band O2 sensors work.
I was just giving an example of WOT tuning. The stock O2 sensors are not going to be reliable at tuning WOT or any other areas of the entire map that it can not sense.
Ok, so you set all the cells to the stoic value and data is collected in those areas that are hit during the run process, including the WOT areas because the O2 sensors are looking at the exhaust flow and switching from too lean add fuel, too rich remove fuel. They have no idea that this is a WOT area, they just know that below a certain voltage is rich, above a certain voltage is lean (actually this is the ECM interpreting the voltage recieved from the O2 sensors).
I never said it was limited.
I am not confused, but I believe your understanding of the tuning process as it applies to SmartTune is flawed. I have no experience with PowerVision but I believe the process using the Narrow band sensors is likely the same.
Their function is to sense a specific AFR and return a specific voltage based upon what they sense (there is a small degree of adjustment in the O2 bias table).
Wide band sensors are able to return a wider range of voltages based upon what they sense, so yeah a wide band sensor can return a value that the appropriate ECM could interpret as 12.5 but SmartTune isn't trying to tune to specific AFRs. It is correcting your VE tables so that the open loop values in your AFR table will be accurately reproduced.
Like I said before, SEPST is designed to produce a race quality WOT tune, and can be used very effectively on a Dyno. Once VE tables are calibrated, I could use a wide band exhaust sniffer to verify the AFRs.
It is shaking a lot more at higher speeds than before,so I'm thinking it needs a bit more fuel.
