Tank Lift before & after
Old 02-07-2007 | 12:50 AM
Gamma742's Avatar
Gamma742
Default RE: Tank Lift before & after
I paypaled you the funds
Old 02-07-2007 | 01:13 AM
Helix's Avatar
Helix
Jackyl Could you please paint mine Gloss Black , forgot to tell you that in my PM! I Sent the Funds earlier today. Thx!
Old 02-07-2007 | 06:05 PM
jackyl's Avatar
jackyl
ORIGINAL: Gamma742
sent it out this morning
Old 02-07-2007 | 06:06 PM
jackyl's Avatar
jackyl
ORIGINAL: Helix
yes i did .and sent it out this morning
Old 02-07-2007 | 11:34 PM
trever.thompson's Avatar
trever.thompson
Did you have a dealer do this? Or did you do it yourself? How much does it cost? Looks damn good!
Old 02-07-2007 | 11:39 PM
Gamma742's Avatar
Gamma742
I'm no wrench but I'll do it myself..
Couldn't be any harder than the garage door opener or the air horn I installed. I do better with mechanical vs. electrical..
I would like to know.. How do I remove the crimp on hose clamps on the gas line?
Old 02-07-2007 | 11:55 PM
mud's Avatar
mud
muderator
ORIGINAL: Gamma742
Diagonal cutting pliers.
mud
Old 02-08-2007 | 07:23 AM
jackyl's Avatar
jackyl
ORIGINAL: trever.thompson
its a easy bolt on,you can do it yourself..no dealer needed.i sent you the info
Old 02-11-2007 | 04:33 PM
Gamma742's Avatar
Gamma742
I couple of things for you Low Riders thinking of a tank lift...
Let me start off by telling you the lift bracket itself it top quality...
The 2" lift does create two problems.. When turning to the right it hits the bolt that retains the brake line. Second iswhen turning to the left it hits the tank.
If I shorten the stopper so the fork bolts don't hit the tank, then I won't be able to lock my forks[]
The bolt that shipped with the lift kit was about a quarter of an inch too long so I switched it with the one securing the rear of the tank. This makes the tank lift in the front have matching bolts and nuts. Notice the in the first pic the nuts are long and capped on the end. I'm going to run to the local hardware store to try to find the same size bolt and a closed cap nut like the OEM version. I'm afraid that the extra lenght of the bolt will cause the threads to cut into the seat.
I'm most concerned about the triple tree bolt hitting the tank on the left but I want to still be able to lock the forks.
[IMG]local://upfiles/20253/9F8D753BDCE345CCB759FB8C0269EB62.jpg[/IMG]
[IMG]local://upfiles/20253/08F2B53224C94DFF8D0C64BCC01CD915.jpg[/IMG]
[IMG]local://upfiles/20253/A405C22599FC4F3CB8B88E3117C392C0.jpg[/IMG]
Old 02-11-2007 | 07:13 PM
jackyl's Avatar
jackyl
gamma 742 thanks for the complimentfor the qualityof my mount. if you want, i can send you a shorter bolt if you would like, just P.M. me. if your scared of the trees hitting the tank or being close to the tank. then you might want to buy a triple tree adjustable stop from the dealer for $9.95.its easy to install to, itsso your front end does'nt rotate as far side to side.
Quick Reply: Tank Lift before & after
