Triple tree adjustment help
Old Feb 8, 2013 | 03:35 PM
dirtdobber's Avatar
dirtdobber
that is called tweaking. It is really more normal a lot more than you think.
just loosen the top bolt on the triple tree like another poster said and use something against the front tire to hold it solid. Do not remove or loosen too much, that is why I said the top pinch bolt, turn handle bars until straight but also make sure it is the triple tree not the bars. the risers could be off some to, like another poster mentioned.
It is really a simple correction.
Old Feb 8, 2013 | 05:24 PM
DJY's Avatar
DJY
Originally Posted by jmeiers
I'm curious as to how the trees are crooked? Not insulting or anything like that, just trying to understand the issue.
I don't see how they could be crooked once the fork tubes and front wheel is mounted.
Is it not just your bars/risers that need adjusting? Is your front tire wearing improperly?
sorry to hijack, but gotsta know what seat that is?
Old Feb 8, 2013 | 10:46 PM
jmeiers's Avatar
jmeiers
Thumbs up
LePera Bare Bones
Old Apr 1, 2013 | 12:11 PM
Csands's Avatar
Csands
Ok I know it's been awhile, but here's an update. Jacked the front end up to take weight off the front end. With a black marker made a line on tree and fork, then loosened all 4 pinch bolts, raised and lowered jack so forks slide free in triple trees. Put it back at the right height and tightened bolts. Fork on left side was twisted, because the marks were off set on that side, also it felt like it went right into place.
Took it for a test ride and its where it should be, looks like it should.
Tynomite
Apr 22, 2015 08:55 PM
BigWave
Jun 4, 2013 08:58 PM
tincup64
Mar 11, 2012 12:20 PM
jb27
Mar 9, 2011 10:10 PM
85RoadsterXLS
Feb 17, 2007 11:34 AM
