StreetBob 96 or 103?
Old 02-10-2013, 08:01 PM
triumph900's Avatar
triumph900
triumph900 is offline
Default StreetBob 96 or 103?
I've heard (but haven't actually been able to compare) that the 103 engine is "smoother" than the 96. Any truth to that? I'm thinking of possibly ordering a Street Bob through the HD1 program, which gives the option of the 103. So is it worth it?
Old 02-10-2013, 08:10 PM
omaho5's Avatar
omaho5
omaho5 is offline
What is the $$$ difference ?
Old 02-10-2013, 08:18 PM
mmcbeat's Avatar
mmcbeat
mmcbeat is offline
I used to own a '11 SB with a 96 and have ridden both. The difference I notice, 6th gear is more "usable" with the 103.
I might be mistaken but I think you have to go with the 103 if you order through the HD-1 program. The 103 is about $350 extra.
craigffb's Avatar
craigffb
craigffb is offline
$350. Get the 103. More low end grunt. And as mmcbeat said you can run the 103 in 6th at much lower speed then the 96.
Old 02-10-2013, 08:19 PM
Northbound Southerner's Avatar
Northbound Southerner is offline
Same motor...Different bore...What does the upgrade cost? You also get ACRs with it. Not sure if they are stock on the newer 96" motors. If less than 1000.00, it's worth it...
Old 02-10-2013, 08:34 PM
fireman64's Avatar
fireman64
fireman64 is offline
Received 1,583 Likes on 329 Posts
I suggest the 103. I love mine!
Old 02-10-2013, 08:43 PM
SLV's Avatar
SLV
SLV is offline
Get the 103. It's worth it.
You only have to upgrade if you choose a non-standard color (anything other than black.)
The upgrade costs $350 for a black motor, $750 for chrome.
Look at a few other factory options to save money:
Fwd controls are $180 installed. $400 plus labor if bought separate.
The two up seat and peg kit is also cheaper if ordered from the factory.
PistolPete83's Avatar
PistolPete83
PistolPete83 is offline
At $350. If you don't get it you will regret it after...
Old 02-10-2013, 10:04 PM
Joboo1966's Avatar
Joboo1966
Joboo1966 is offline
Get the 103 in terms of money it makes the most sense.
Old 02-10-2013, 10:08 PM
Joboo1966's Avatar
Joboo1966
I love the look of your scoot brother! Nice lines, color and set up.
Bravo!
Quick Reply: StreetBob 96 or 103?
