Power Vision/ Auto Tune Basic
Old Feb 11, 2013 | 12:19 PM
Rfc's Avatar
Rfc
Default Power Vision/ Auto Tune Basic
I did a basic run on one of the fuel maps Jamie sent me just to see what it does. I can't tell any difference on the modified tune from the original one. Would somebody please explain in layman's terms exactly what this does.
Old Feb 11, 2013 | 12:23 PM
soft 02's Avatar
soft 02
Originally Posted by Rfc
I did a basic run on one of the fuel maps Jamie sent me just to see what it does. I can't tell any difference from this modified tune from the original one. Would somebody please explain in layman's terms exactly what this does.
I can not but I can tell you that Jamie's map is pretty darn close to optimum!
Old Feb 11, 2013 | 12:49 PM
markrumsfield's Avatar
markrumsfield
Should have made some changes to your VE tables. If you up load your recently auto tuned map to your computer you can compare it to the origial FM map. In Winpv if you load one of the maps, then click load compare and load the other you can then view the differences/deltas between the VE tables of the two maps.
Old Feb 11, 2013 | 04:42 PM
HD Pilot's Avatar
HD Pilot
I think that Jamie has done so many maps now that the Autotune feature just polishes up the VEs now. After my first Autotune, I did not notice any big changes either and when I used the Compare feature in WinPV, there were changes but none of them dramatic at all.
Old Feb 11, 2013 | 06:07 PM
Ratbob's Avatar
Ratbob
No two engine/AC/exhaust setups have identical Volumetric Efficiencies. Jamie's maps are generally very close, but the better you model your setup's VE tables the more accurately you can expect the engine to respond to your AFR tables. If you really want to understand how your PV works you should be following This Thread.
mpr3369
2014-2024 Touring Models
Mar 24, 2017 06:14 AM
IronHyena
Aug 5, 2016 08:06 PM
shaker
Oct 22, 2013 01:54 PM
gargoyle13
Jun 18, 2013 06:42 PM
supra0001
Apr 16, 2013 05:39 PM
