Bottom end bearings on a 2007 FXD
Old 02-15-2013, 01:50 AM
ckelley63's Avatar
ckelley63
ckelley63 is offline
Default Bottom end bearings on a 2007 FXD
Does any one know about the bottom end bearings being some what weak on the TC 96's I was told their good up to about 100 hp then the bottom ends need to come apart and the bearings replaced with the stronger Timken. I have heard that the cranks are a pressed fit from the factory, just curious as at some point I will be doing the 103" upgrade.
Old 02-15-2013, 03:55 AM
ynots's Avatar
ynots
ynots is offline
The only difference between the 96 and 103 are the size of the bore.
Old 02-15-2013, 03:04 PM
ckelley63's Avatar
ckelley63
I hear you but what about horsepower figures for these motors and the bottom ends?
Old 02-15-2013, 03:07 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,570 Likes on 2,888 Posts
Most say good to 120. Me I spun a rod bearing with it at 96".
Old 02-15-2013, 03:14 PM
ckelley63's Avatar
ckelley63
Really, do you know what caused the bearing to spin? In your pic it looks like the pin end of the rod with the bushing in place.
Old 02-15-2013, 03:16 PM
soft 02's Avatar
soft 02
soft 02 is offline
Bad design + high mileage.
Also not servicable. Have to pull the crank and change out the rods.
Old 02-15-2013, 03:36 PM
ckelley63's Avatar
ckelley63
That sucks how many miles?
Old 02-15-2013, 04:20 PM
soft 02's Avatar
soft 02
soft 02 is offline
118k on my 2007 96"
Old 02-15-2013, 07:49 PM
missedem's Avatar
missedem
missedem is offline
almost 120 k not bad. does sound like a PITA to pull lower end apart but cheaper than a new bike .. good luck.
Old 02-15-2013, 07:54 PM
soft 02's Avatar
soft 02
soft 02 is offline
No worries. Now she will be bullet proof!
Quick Reply: Bottom end bearings on a 2007 FXD
