Front Brake line bolt at Master Cylinder?
Old 03-05-2013, 10:00 AM
ilmonster's Avatar
ilmonster
ilmonster is offline
6th Gear
Steel Steed, not sure if it's in the service manual (certainly hope it would be). I work in the brake system supply chain for H-D though, and the torque spec for Dyna's and Softails is 17-22 ft/lbs with 19 ft/lbs being optimal. Also, make sure you don't lose the washers on either side of the brake line. They usually have a little rubber gromet molded into them (depending on what year and model H-D you have), and it's important to reuse those (or buy new ones). Good luck!
Old 03-05-2013, 07:10 PM
Steel Steed's Avatar
Steel Steed
Steel Steed is offline
I appreciate the tips! My brake line arrived just today too.
Old 03-05-2013, 08:30 PM
Gommee's Avatar
Gommee
Gommee is offline
Devil's Advocate
That is some good info, my new front line is on the way.
Old 03-05-2013, 08:42 PM
ilmonster's Avatar
ilmonster
6th Gear
Happy to help! Now I need to get me a Harley of my own. I know, I work for a H-D supplier and don't own one, but we do have a test garage with eight H-D bikes I get to ride when the engineers aren't using them for testing purposes.
I'm thinking about a Street Bob through the HD1 program, or a Fat Bob. Cheers!
SixDD
04-28-2019 02:17 PM
cycler
12-09-2018 01:58 AM
bigdawgz1
09-18-2013 02:48 PM
rgm
01-23-2013 09:58 PM
BluBob
07-14-2008 04:23 PM
Quick Reply: Front Brake line bolt at Master Cylinder?
