Banjo bolt size????
Old Jan 23, 2013 | 02:53 PM
rgm's Avatar
rgm
Question Banjo bolt size????
What banjo bolt size do I need for the front caliper and front master cylinder on a 2012 Sportster 72? My brake line has the proper connections but they did not include the bolts. So I need to purchase new bolts in chrome to match brake line. Is the caliper 12mm and the master cylinder 10mm.....please let me know, thanks.
Old Jan 23, 2013 | 05:14 PM
tripn88's Avatar
tripn88
Probably both 10mm try calling the dealership and ask them. The dealership I always used was helpful.
Old Jan 23, 2013 | 09:54 PM
mazeppa's Avatar
mazeppa
Single front disk brake 04-13 Sportsters use part # 41736-04 banjo bolt (10mm) for the front/rear brake calipers and the front/rear brake master cylinders.
Old Jan 23, 2013 | 09:58 PM
run1fsr's Avatar
run1fsr
Right, also refer to J&M Cycles catalog. But 10MM sounds correct.
cycler
Dec 9, 2018 01:58 AM
skeeter 250
2014-2024 Touring Models
Mar 29, 2015 04:18 PM
BSR
Dec 14, 2012 05:19 PM
BluBob
Jul 14, 2008 04:23 PM
WarriorHD
Jun 15, 2006 12:37 AM
