How Low can I drop My LowRider
I need to lower my low rider, but do not want to lose handling capabilities nor do I want to have the bike feel front heavy. I was thinking of buying this kit but am not sure what it will do for the handling. Needing advice!
here is the kit I was thinking of getting.
http://www.jcwhitney.com/progressive.../p3074467.jcwx
Also Is it possible to somehow make a new attachment for the reduced reach seat as the mounting bracket where it screws in the back, is like 1/8 " short and I really need a seat like that.
Thanks all for your guidance
Suzanne
Suzanne
I have the burlys on the rear of my bob, and the progressive drop in kit in the front.. I like my bikes low.. Yes, I have lost some handling capabilities, but I'm fine with that.. I still ride it hard. It will definitely ride different once you drop it down, and if your anything like me, you'll have to change your riding style just a little bit.. Lol. Good luck!
TwelveHD, By losing riding capabilities I am assuming you mean you are now unable to lean as much, right? Does the bike ride rougher? and does the rear tire rub under the fender?
I am a women of 5'4 and would like to at least lower it about 1.5 to 2" . Can you tell me is it better to drop both front and back at the same time, and if I do just the back will I be top heavy?
I dropped my rear first, and didn't like the way it looked or rode. The front end seemed to high for me. So I ended up doing the front shortly after, and I'm glad I did. It seems a little more balanced now.
I am not sure what year your bike is but mine is an 07. I am also 5'4". I thought about lowering the bike as well but I did not want to give up any handling or ride quality so I nixed that idea. I actually changed the rear shocks to Progressive 440's and the were a huge improvement over the stock ones. I have not yet changed the front suspension so it is still stock. The rear shocks were the same length as factory so ride height has not changed at all. What I did do was to change my seat. I had a Le Pera bare bones which is probably the lowest seat you can buy, but very uncomfortable after about an hour or so of riding. I traded the seat with a friend for some accessories and ordered a Saddleman Heels Down seat. Very comfortable for me and it still put me at a low seating position. Next I upgraded my work boots to a pair of HD boots. They have a thicker sole and a bigger heel. The combo of the seats and boots was perfect. The bike still has a nice ride quality to it with the Progressive shocks and I can still lean into the turns as well without dragging my pipes on the ground. The foot rests are another story though.....
I would suggest sending your stock shocks too MB products, they will shorten shocks, and turn around time is one day, Mine are now 11' on a 09 fxdl. charges only $69 which includes shipping, Re: the front I put in the drop inprogressive kit, only took about 45 minutes to do, dropped it the full 2" Ride is a bit stiffer but I like it. But I also have switched wheels to 21" front and rear. Good luck with this project.
2WHEELFREAK
03-09-2014 10:27 AM
