Getting ride height geometry correct?
I do take long rides and like the feel of the bike as is now, I know the handling will change some and that's fine, but I want to keep the ride as close to stock feel as possible with the new wheels. If I go to a set of PM Gatlin's with a 21" front and 17" rear how much do I need to lower my bike to get the same geometry as stock? The stock wheels on my FLHTK are 17" up front and 16" out back. I know I will have to drill my stock fender but I just want to know how much the bike needs to be lowered front and rear to have the same ride as stock.
Thanks
2.) you can generally "lengthen" the front forks ( dropping the rear, leaving the front the same as alluded to in the HD lit you reference, or even extending the forks- this make for nice stable high speed ride, little hard to steer at low speeds.
reversing that makes for very unstable bike at low speeds.
when a 21 goes on the front you are essentially lengthening the front, which is OK.
you need to retain stock or over, rake vs trail
BUT if the forks are dropped to bring the front back down ( even if correct rake/ trail) you may have a problem with the fender smacking the triple tree on a big bump- which is kinda big surprise.
lots of guys have 21's looks awesome, I dunno how much they actually ride them- like bar hopping ok, but maybe not riding to Sturgis
Mike
Mike
I will find out the tire profile. So are you saying its better to drop the rear and leave the front alone vs the opposite?
If adding about an 1 1/2" height from the 21" wheel, and lowering it 1" , does that bring the bike closer to stock and handling closer to stock and opposed to being "tippy" at low speeds? Or just the fact that the tire is more narrow make a diff?
OK, scratch this part, just looked it up at the HD site, 150 clams for the kit, and for me...Dealer job. Lol. So how long at the dealer? Labor cost.
Also, I read on the kit description, that this:
"Must only be installed on vehicles equipped with ProfileŽ Low Touring Shocks P/N 54635-09"
So is that a "must" or is this HD just wanting to sell more?
