I'm running Kuryakyn strut mount mini bullet turn signals and a sidemount license plate/ tail light. The signals only use two wires, instead of three like the stock signals, so I removed the third wire from the harness.The signals function as stop lights and turn signals, not running lights. The tail light functions as the running light and stop light.
I have to figure out something to do with my lights due to ordering T-sport bags. I can't run any of the lights I have. The bags mount to the same hole as the signals, and the side mount is in the way of the bags. I have a shaved fender so going to a stock style tail light isn't an option. I can order a new signal harness if I need to for the three wire hook up.
Anyone know of some small-ish signals that will function as run/turn/stop lights that I could use with a relocation kit, and what module, if any, is needed to make them work?
I'm ordering a hogrida plate and will re-drill the three mounting holes for the plate.
man save your $$$$ go to the auto parts store get a trail converter... super easy and they work great! that is how i did chris old bag set up a while back... they are like $10 and work great
Im just running the HD R/S/T mdule with Joker Machine Astro signals and an Edge chopper fender light. Im only running the tail light because I liked the way it looks and I figured a little extra light couldn't hurt. But the signals do fine on their own. I bought a Biketronics load equalizer but I didn't need it. I believe the HD R/S/T module has a load equalizer built in to it.
Joe that would work, but it doesn't solve my signal issue. The strut mount signals won't work, or at least won't look good, on the relocation bracket. The backs are curved to fit on the end of the struts.
BlueAngel those LEDs look like they might work, but I don't know how they'll look run across the surface of the fender. I couldn't see the pics in your thread you posted on the install, just the video
Spankdog that tail light would be perfect, except I have a full length FXD fender and it won't fit, and would point right at the ground.
This is turning into one of those "why did I do this" mods.
