Nacelle for Dyna
In my world a nacelle is what covers aircraft engines. So what exactly are you asking about? A fairing? Please dumb it down a bit for me.
Talking about the headlamp nacelle. It typically covers the trees and houses the headlamp.
I'm sure someone will jump in to say I am wrong, but there doesn't seem to be a bolt on nacelle for a Superglide, Street Bob, etc. A few things are considered including the tubes are 49mm, the width of the trees, location of the headlight. A Switchback has a nacelle, but the front end is a different design than the above mentioned bikes. I have considered attempting to build one, but if you use tin, you would have a lot of cutting and welding, then chroming, if that's the route you want to go. I have thought about grabbing one from a swap meet and attempt to modify it. I have looked at a few, but can't recall if they were aluminum or pot metal. If it is pot metal, I wouldn't even venture, but if it's aluminum and you can weld aluminum, you could polish it to a high gloss and it would look great. I'd be interested in other options or ideas if anyone has any.
I have been looking for years for any tins or slider covers for 49mm front ends, haven't found anything yet. Most guys that really want tins go with an FL Softail front end. My father went with the 1960-84 FLH front end using modern forks. A little grinding on the lower trees was needed but it has worked perfect for 2 years. Here is a picture during the build of his 2005 Superglide.
Speak to Gary at oldinc.com. They make a composite nacelle ( amoungst other things) and could probably work with you to make a custom size one. They'll do thier fenders in any size you ask for, so the nacelle might be possible as well.
