Help!!! with rear rim swap from 17" to 16"
Old 07-18-2013, 04:34 PM
wattsupFXDC's Avatar
wattsupFXDC
wattsupFXDC is offline
Default Help!!! with rear rim swap from 17" to 16"
I have a 2009 FXDC Dyna Glide Custom. Need to swap rear rim from 17" stock to a 16" so I can buy 160 or 180 whitewall tires. What is the right axle size (3/4" or 1") and rim width dimension (3", 3.5"....)
Please help!!!
Old 07-18-2013, 07:37 PM
thedonthere's Avatar
thedonthere
thedonthere is offline
your axle size is 25mm your rim width is 4.5"
Old 07-18-2013, 08:24 PM
macnab_sf's Avatar
macnab_sf
macnab_sf is offline
If he's gonna run a 180, shouldn't he get a wider rim? (Not counting the one or two HD "skinny" 180s designed for the stock rim)
Old 07-18-2013, 08:37 PM
DoomGloom's Avatar
DoomGloom
DoomGloom is offline
A Fat Bob rear wheel is an easy swap. Gets you the 16 X 5 inch wheel and the ability to mount any 180 series tire without a tube.
Rusty Axle
Shovelhead
12-06-2016 02:10 PM
jmerchant.1
08-23-2015 11:42 AM
jamesf0622
EVO
05-19-2012 03:22 PM
burntcookie10
06-24-2010 08:05 PM
74_ironhead
Ironhead
05-18-2006 11:37 PM
Quick Reply: Help!!! with rear rim swap from 17" to 16"
