Air filter
Thanks Guys! That DK cleaner is where I'm going. You guys are awesome! When I first got on the forum, my mind was reeling with the knowledge I was reading and I don't want to jump to quick on something I didn't need...$$$. This thread helped a lot, sorry for asking (to some) very simple questions. I just got this bike and want to give her the best without taking out another loan. Rick PS I don't want the fastest bike, just one that runs sweet and clean............ Thanks again
I have the K&N street metal intake that I purchased for $161.00 and I've have seen them cheaper more recently. I only have Python slip-on mufflers and no fuel management. My bike runs totally fine. I pulled my plugs the other day and they looked fine. I want a fuel management some day. Will probably just throw on some xieds or a fuelpak and call it a day...
The Screaming Eagle non-oiled cleanable filter may give the best of both worlds.
I only use them when space restrictions make them necessary, or when the filter will get wet, like on one of my supercharged vehicles. I believe the non-oiled Screaming Eagle filter will be fine wet too though. At least it's still worked fine for me when it got drenched.
Ok man. But you really should go back and read what you've been sayin.
OK Man. I was going to leave it alone. But since you asked.
You said that they initially flow better than paper.
Then you said give them "Egual" amounts of dirt
So they would have equal amounts of restriction. But, since the oil filter started out with more flow. It should still have more flow than paper. Not this \/ \/ \/
Now PROVE IT.
while they may flow better initially than
when they have been fed equal amounts of dirt
Flow will quickly go below that of a good quality paper filter
Here's one test of a bunch of different filters, including a K&N.
http://www.nicoclub.com/archives/kn-vs-oem-filter.html
Note that the AC paper filter not only traps a lot more dirt, but also doesn't load up (lose flow) as quickly. The K&N quickly becomes more restrictive than the AC paper filter.
