Rhythmic Chirp
Old Sep 24, 2013 | 06:33 PM
joelorensen's Avatar
joelorensen
Default Rhythmic Chirp
I have a 97' FXDS with lowering blocks in the rear (came that way). Anyway, after starting a warming up, everything sounds normal......when I sit down (I'm 185 lbs) a rhythmic chirping starts. If I stand up, it goes away, when I sit, it starts again.......any thoughts? Btw, I have the factory shocks set to the stiffest preload notch.
joe
Old Sep 24, 2013 | 06:55 PM
bobnehoc's Avatar
bobnehoc
Might be time for a new pair of shocks. The rubber parts inside are probably worn and drying out causing the chirping sounds. You could spray some lube on the rubber bushings and see if that fixes the problem.
Old Sep 24, 2013 | 08:39 PM
joelorensen
hmmmm......I'll give that a try, thanks!
Old Sep 25, 2013 | 05:16 AM
RudeDog's Avatar
RudeDog
I have a 1998 FXDS and I also had that problem I found it to be the stock saddlebag mounts, where the bag mounts to the back of the fender, were squeaking, the nuts inside the fender was rubbing on the holes in the fender.
yosemite91
Mar 4, 2017 03:33 PM
hfp3030
May 16, 2012 12:20 AM
rrouse4761
Dec 26, 2010 10:42 PM
cohoona
Jul 31, 2008 06:22 AM
baxter
Apr 6, 2007 10:18 PM
