pipes and reprogram question
Old Sep 24, 2013 | 07:17 PM
Midge54's Avatar
Midge54
Default pipes and reprogram question
So i just purchased a set of vance and hines short shots from the classified section for my 12 Wide Glide. My question is with just the pipe change, do i need to have the ecu modified or can i wait until i change the air filter out
Old Sep 24, 2013 | 07:23 PM
KEYBEAR's Avatar
KEYBEAR
Just Wait no big deal . The ECU will adapt to JUST pipes
Old Sep 25, 2013 | 04:15 AM
rawdog7's Avatar
rawdog7
You can even throw on a aftermarket air cleaner!
Old Sep 25, 2013 | 05:11 AM
maddghost's Avatar
maddghost
He could but he'd be getting near the edge.
@ midge just pipes = no problem, that's as far as I'd go without a re-tune.
Old Sep 28, 2013 | 08:42 PM
Midge54's Avatar
Midge54
Went to the dealership for open house last night and talked to them about stage 1 options. Basically they said the download would enough to make the bike run right, however it was 149 for the download and 40 for install. He also said that a tuner with a dyno would run better but that would mean 400 for the race tuner and another 400 for the dyno tune. I really didnt like either option so i ordered a pair of of nightrider FL-VIED for the wide glide, i bought them off ebay so i hope they are ok. Who has used the new variable set of these and what setting are you running. I plan to get a screaming eagle stage one air cleaner once i can find the $150 extra, specially with the government shut down meaning we wont get paid.
Old Sep 29, 2013 | 01:29 AM
bdtaylor1979's Avatar
bdtaylor1979
What he said
Old Oct 2, 2013 | 06:38 PM
Midge54's Avatar
Midge54
i put my short shots on yesterday, rode it ran good with them, better than stock, today i got my xied that i bought on ebay, at first didnt notice much difference however by the time i was done with about a 30 min ride it was really starting to run better. It still has a slight pop on decel but not to worried, next step an air cleaner
Old Oct 2, 2013 | 08:24 PM
99%r's Avatar
99%r
I have a set of VIEDs, they work good. Took the pinging out,and runs cooler.
Old Oct 24, 2013 | 05:23 PM
sgr60's Avatar
sgr60
At what point do you need to get a dyno tune - with pipes and air cleaner? What happens if you don't?
Old Oct 24, 2013 | 05:26 PM
sarpeezy's Avatar
sarpeezy
Id like to know this as well, I have a fuel pak on the bike so idk if that helps but would i need a tune when theres an air cleaner?
