National Cycle or H-D windshield
Old 10-27-2013, 09:23 AM
marcortez's Avatar
marcortez
marcortez is offline
Default National Cycle or H-D windshield
2011 FXDC SuperGlide
I am about to pop for either the National Cycle "Spartan" windshield or the H-D compact model.
Of particular interest to me is the quick release mounting system.
The H-D one seems (online visual) to be a slicker setup over the National Cycle model. The mounting hardware on the H-D is not left behind to stay on the fork tubes, whereas the National Cycle ones are.
And a lock is available for the H-D model at extra cost, whereas I cannot find a lock for the National Cycle model.
Can anyone please comment on either of these two mounting systems?
The mount for the H-D model is included in the price, whereas the National Cycle is an extra, albeit required, add-on purchase, however the National Cycle "Spartan", with the mount, is about $30 bucks less than the H-D....... buying from JP Cycles.
For reference: National Cycle http://shop.nationalcycle.com/perl/c...&search_model=
H-D http://www.harley-davidson.com/store/quick-release-compact-windshield-pa-20-5834606--1
A mouse over will enlarge more detail of this mount.
Thanks
Old 10-27-2013, 09:35 AM
MrPappagiorgio's Avatar
MrPappagiorgio
MrPappagiorgio is offline
I have no experience with the national cycle but I do have the HD windshield. The mounts work very well, look nice and are easy to take it off and on.
Old 10-27-2013, 09:53 AM
Bigman405's Avatar
Bigman405
Bigman405 is offline
If have a national cycles windshield called the switch blade. I love it.
Old 10-27-2013, 10:06 AM
jpicht's Avatar
jpicht
jpicht is offline
Default Modified windshield
The HD quick-release system is very nice. I like to ride without the shield most of the time and it's great to be able to replace when I want to in about 10 seconds. However, the HD shield is somewhat flimsy compared to Clearview or Long Ride Shields. Plus those are recurve which allows a much lower shield to still get the same or better coverage. I bought a used HD shield and used the clamps and brackets to mount to my Clearview replacement shield. You should look into the same setup. You'll save $ and have a better product to boot.
Here is one on E-Bay: http://www.ebay.com/itm/OEM-HARLEY-U...-/261314716836
Make sure it is for the 49 mm forks.
Old 10-27-2013, 02:48 PM
ashus's Avatar
ashus
ashus is offline
6th Gear
Quick release on the HD model is gr8 but be prepared for annoying buffeting above 60 mph and headache inducing buffeting heading up towards 80mph
Old 10-27-2013, 07:47 PM
DoomGloom's Avatar
DoomGloom
DoomGloom is offline
I have the National Cycle Spartan Shield on my Street Bob....compared to the Harley shield, it is of much higher quality....the Harley shield is easily flexed the Spartan is made of a thicker harder to scratch material. I have the 18 inch shield.
The Harley mounting system is nice and leaves nothing behind and is lockable....there are no locks for the Spartan, but that was not a concern since Im running a 7 inch headlight and it would have to be lowered out of the way to remove the shield........
Thought Id remove the shield for local rides, but Ive never taken it off since installing it......
Old 10-27-2013, 07:56 PM
DoomGloom's Avatar
DoomGloom
Here's some pics of the National Cycle Spartan shield
Old 10-27-2013, 08:11 PM
marcortez's Avatar
marcortez
Perfect Mr Gloom.....thank you very much for your time and efforts to post up those photos.
Old 10-27-2013, 08:29 PM
jojo2dog's Avatar
jojo2dog
jojo2dog is offline
running the hd quick release , nice fact is you can move it up or down very easy. nice weather I mount mine below the lower triple tree with the bottom mounts and if the weather turns bad all you have to do is stop and move it up,
Old 10-27-2013, 11:49 PM
kokemill's Avatar
kokemill
kokemill is offline
I have 3 HD quick releases and switch them between my Dyna and Sporty. I don't have any problem with buffeting at 60, 80 or at cruising speeds.
Quick Reply: National Cycle or H-D windshield
