Wheel Bearings
Old Dec 2, 2013 | 03:36 AM
ebeattie's Avatar
ebeattie
Default Wheel Bearings
Hi all. 2012 Fat Bob FXDF. need info on bearing part numbers and quantity. Have heard that 1 on each side of front wheel and 2 for drive belt side of rear and 1 bearing on brake side. Truth to this?
Thanks!
Old Dec 2, 2013 | 05:12 AM
SuperFastGlide's Avatar
SuperFastGlide
2 bearings per wheel
Old Dec 2, 2013 | 06:30 AM
stilup's Avatar
stilup
yup on my fxdb 2 bearings per wheel
i went from stock chinese junk to alballs to timken(fafnir)
get the timken (fafnir)
I change them every other tire change both axels.
Now with the timkens in I may stretch that chnge out allot more.
Old Dec 2, 2013 | 09:04 AM
ebeattie's Avatar
ebeattie
Old Dec 2, 2013 | 09:17 AM
JaronB's Avatar
JaronB
I also switched to the timken (fafnir) ball bearings. So far so good!! They are tractor bearings rated at 1760 lbs static load and 3600 lb dynamic load. As long as some farmers let these run in their tractors I think we should get a decent life out of them.
Part number 205PP
My axle is 25mm or 1 inch. I'm pretty sure yours is the same, but double check.
shorty07ultra
Oct 14, 2023 03:46 PM
JakeUSAF
2014-2024 Touring Models
Oct 5, 2017 02:52 PM
stlboarder
Jan 11, 2010 07:36 PM
vetto
Wheels/Tires
Jan 30, 2009 02:37 PM
CaptainBastard
May 1, 2008 08:30 PM
