Dual Front Brake Conversion
Was looking to put a dual front brake set up on my 02 super glide and was wondering what's the best way to go about doing this. Is there a kit or do you buy the caliper, rotor, fork tube, and brake line seperate? Thanks
Best bet is to get the leg and other parts source used ones might take a while but will save you a lot of coin. The classifieds on this forum have some good stuff. I did the Brembo swap on my dx all from this forum.
Check out this Instruction Sheet for the dual front disk brake kit...
(more Instruction Sheets to be found over here: ***H-D instruction sheets database***)
My 03 FXDP police bike came stock with duals.They will work on your 02. Here are the HD part numbers.
Right lower slider - 45922-00
Right caliper - 44023-00A
Upper mounting bolts 2 needed - 44163-00
Lower mounting bolts 2 needed - 44160-00
You may have to do custom brake lines depending on your handlebars but the stock part number is 45083-01. Also not sure if your stock master cylinder will work with the duals, you may have to go with a set that has a larger bore. Hope this helps.
