hayden adjuster/SE compensator
Old 02-05-2014, 09:06 PM
hell hound's Avatar
hell hound
hell hound is offline
Default hayden adjuster/SE compensator
who has this tensioner and how do you like it
who has it and does not like it
in the middle of tranny/primary work and looking at options
same question with SE compensator
lookig for all opinions on this
Old 02-05-2014, 09:17 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,570 Likes on 2,888 Posts
As a mechanic I prefer the Baker unit. Chains dont stretch much and the M6 seems small and light duty. IMO.
SE comp is a temporary fix but there are other options like the BDL screw comp and someday Darkhorse is TBA.
Old 02-05-2014, 10:11 PM
misfitJason's Avatar
misfitJason
misfitJason is offline
Received 1,031 Likes on 652 Posts
I have the m6 and it seems to function well. It was a bitch to get in there but once it was in not a problem. It quieted my shifting down a little
Old 02-05-2014, 10:25 PM
hell hound's Avatar
hell hound
i posted this in a thread i started in the drive train section but i guess it doesnt hurt to post it here too. originally i thought i was hearing my ipb going out but it turns out it is the roller bearing in the tranny. i took a look at it today
here is the slide part on the stock compensator. it is 06 dyna but the rotor is an 07
this picture is the worst of it
Old 02-05-2014, 10:27 PM
HD Bobber's Avatar
HD Bobber
HD Bobber is offline
I got the SE comp for my 106 build along with the hayden. Read many fantastic reviews on the hayden over the stock ratcheting unit which way over tightens and doesn't back down.
As for the tensioner a the baker and hayden are great choices.
As for the compensator the SE is absolute insurance for your frank when you build your motor and the only choice as of now. I saw the darkhorse setup and it looks great!!!...but still in some development. The current SE Compensators are the second and improved models. The previous design starved of enough lubrication and was known to burn up.
The BDL I would never consider since it does nothing for cushioning the power transferred to the crank.
Old 02-05-2014, 10:31 PM
hell hound's Avatar
hell hound
here is the roller bearing in the tranny, it is wasted
lots of movement up and down on the main shaft so pulled the seal to look
like i said i posted this in the drivetrain section but thought why not put it here too for more opinions
Old 02-05-2014, 10:36 PM
HD Bobber's Avatar
HD Bobber
Time to get the baker bearing. Don't get another HD replacement.
Old 02-05-2014, 10:37 PM
soft 02's Avatar
soft 02
soft 02 is offline
Yep. Changes 5 or 6 of those in my trany.
Old 02-06-2014, 07:55 AM
mattVA's Avatar
mattVA
mattVA is offline
Soft I can't believe you haven't abandoned HD altogether after doing it that many times. One tranny teardown was enough for me.
Old 02-06-2014, 07:59 AM
soft 02's Avatar
soft 02
soft 02 is offline
After changing my comp, IPB, and tensioner they quit going bad. Im re building the whole tranny this month. I should have all my parts this week. Having crap fail gives me a chance to make it better than stock. By the end of the year I will have rebuilt/repaired 95% of this bike. Next year im replacing the wiring harness.
Quick Reply: hayden adjuster/SE compensator
