Ive got a 1340 fxds. Blowing oil on carb side, I ran a hose down from crankcase breather after everyone said it was blowing oil in carb. Took it out today and I have oil everywhere on the side of my bike, dripping down off bottom of gas tank, noticed it on top of oil filter and even around exhaust ports...what's the most common cause?
How do you drain crankcase...I should have said earlier I'm an idiot...got a clymer manual and this website to go by...I will degrease and see what I can find
Ok, I checked oil level...it's just above the fill line...so not over full...going to run it now see if I can find leak...I'll post pics later..thanks for the help
Check it again after its ran a few minutes. It may show overfilled then if you have a bad checkball in your pump.
Ok I can see it is leaking where the rocker arm cover sits on the cylinder head on the front cylinder. It's leaking pretty good and when I ride it it blows everywhere....gasket? Or do I have bigger problems? Is this something a novice can fix with a manual or should I take it in to get repairs?
From what I read it's the lower rocker arm metal gasket because the leak is coming from where the rocker arm cover sits of the cylinder head....I'm going to assume this will be a pain to fix myself
