bolt size
Old 03-07-2014, 09:25 AM
Guest
Guest
Posts: n/a
Default bolt size
anyone know the correct bolt size for attaching the rear peg mounts to the frame.. my bike was set up for solo when i bought it, rear mounts were not on the bike.
Old 03-07-2014, 10:24 AM
DJY's Avatar
DJY
DJY is offline
Sorry I can't help ya, but hell yeah on the DIO.
Old 03-07-2014, 12:07 PM
ynots's Avatar
ynots
ynots is offline
The oem for 06 and up is a button head self-tapping 3/8-16 x 1 in. screw
Old 03-07-2014, 12:22 PM
Guest
Guest
Posts: n/a
Thanks.. i look at that picture and see my bike..lol
Old 03-07-2014, 12:23 PM
Guest
Guest
Posts: n/a
Originally Posted by djy
sorry i can't help ya, but hell yeah on the dio.
r.i.p. Dio
Old 03-07-2014, 12:31 PM
Guest
Guest
Posts: n/a
do i really have to loosen the belt and move the tire forward just to install the bracket?. seems like a lot to put that on..does'nt just bolt on?
Old 03-07-2014, 12:39 PM
ynots's Avatar
ynots
ynots is offline
Its a tight area but you don't have to loosen the belt if you have the right tools. I busted it (belt guard mounting bracket) loose with a 90 deg torx then used the short bit below.
Old 03-07-2014, 03:39 PM
mirrmu's Avatar
mirrmu
mirrmu is offline
Hi,
When i removed mine from wide glide the left side was easy but the right side you need small torx bit like ynots posted with wrench on it,
Drop the back wheel down if you have a lift too
Thanks
Mirrmu
Gitarded
05-21-2019 08:44 AM
Bocephus205
05-30-2016 08:49 PM
Spankinhenken
03-25-2013 10:12 PM
bbqbrisket
07-21-2011 07:46 PM
HOGRIDA_06
03-14-2008 12:40 PM
Quick Reply: bolt size
