2014 Low Rider Muffler Options
Old 06-01-2014, 06:53 AM
orgredneck's Avatar
orgredneck
orgredneck is online now
Default 2014 Low Rider Muffler Options
Hi all,
Just got a new Low Rider Saturday,
wanting to get better muffler.
what options are available.
looking for ideas some have done.
were is the cat in header or muffler.
thanks for the help,
Don
Old 06-01-2014, 07:31 AM
modular's Avatar
modular
modular is offline
The cat is in the collector after the headpipes but before the single muffler. I went with the S.E. Nightstick and installed a L.A. Choppers adjustable end cap and leave it in the fully open position for a bit more rumble as the closed end cap as supplied was very quiet. I also removed 10 of the 14 disks as an open end cap is equal to 10 disks since this is a Supertrapp muffler made for H-D. The cat will be the final determination of how much sound one gets with a slip-on.
I was considering doing a complete aftermarket 2-1 exhaust but since installing a FuelMoto tuned PCV I feel no need for it. I may keep an eye out for a different slip-on but no one as yet makes one for the Low Rider.
Old 06-01-2014, 10:29 AM
aviscomi's Avatar
aviscomi
aviscomi is offline
If you're looking for a full system, then I would consider the V&H Pro Pipe
Old 06-01-2014, 11:34 AM
DynamicDyna's Avatar
DynamicDyna
DynamicDyna is offline
Former Sponsor
Originally Posted by orgredneck
Hi all, Just got a new Low Rider Saturday, wanting to get better muffler. what options are available. looking for ideas some have done. were is the cat in header or muffler. thanks for the help, Don
the Best clearance and performance is bassani 2into1
Old 06-01-2014, 11:48 AM
modular's Avatar
modular
modular is offline
He was asking about slip-on options. And I quote......
Wanting to get better muffler.
Old 06-01-2014, 01:05 PM
orgredneck's Avatar
orgredneck
Looking to get a slip on muffler.
Would you have pictures of your set up.
did you remove the cat?
thanks,
Don
Old 06-01-2014, 01:14 PM
modular's Avatar
modular
modular is offline
Well, sure! Hope these help.
Old 06-06-2014, 09:25 PM
orgredneck's Avatar
orgredneck
anyone change muffler yet,
can't find any options,
except the S.E Nightstick
thanks
Don
thanks,
Don
Old 06-06-2014, 09:54 PM
2>4's Avatar
2>4
2>4 is offline
Modular, did you consider installing an open end cap from Supertrapp? How much louder than stock is your exhaust now? Do you get any decel popping with your set up? Thanks.
Old 06-07-2014, 07:27 AM
modular's Avatar
modular
modular is offline
I am thinking about trying the Slotted Wheel Trapp Cap #402-1020 but the open area is about the same on the L.A. Choppers and Trapp Caps. I did not like the finish on the standard Supertrapp stainless open end cap.
Here is the long story.....When I installed just the slip-on as supplied by H-D (14 disks and closed end cap) it was still pretty darn quiet.....and I don't like loud exhausts. There was a very small amount of gurgling under decel and an occasional puff between shifts but NO popping. No more surging than you get stock with the lean tuning.
Then I added the L.A. Choppers in the fully open position and a Kuryakyn Velociraptor intake. This made the gurgling a bit more severe but still no loud popping so I went to a K&N intake #RK-3922. This helped the gurgling as I have now proved to myself that the Velociraptor intake caused this on both this bike and my '12 XL1200C. I would say the exhaust is 50-60% louder than the OEM muff.
I added in a set of ViED's and that helped a bit more but the gurgling was still there but nothing between shifts. I then removed 10 disks as that is what an open end cap equals to. Helped a bit more but still not to my liking as I do not like any noise under decel. I removed (and sold) the ViED's and installed a FuelMoto tuned PCV. Night and day difference and just where I want it. I have a FuelMoto tuned PCV on my '12 XL1200C and should have done this from the get-go.
Quick Reply: 2014 Low Rider Muffler Options
