Brake Lever a bit Loose & Keeps Light on
My 2012 Fat Bob has about 6,000 miles. The brake lever is a bit loose and keeps the rear brake light ON all the time. If I manually push the lever forward, the light goes off but when I stop pushing it, it goes back to press the on-off switch. The brake action seems ok, not spongy.
I checked the service manual and it only shows one spring against the plunger. Could it be that the spring needs to be replaced to push the lever out? Or are there any other ideas or something there that could be causing this. I haven't taken the lever apart, yet.
You're not showing the right diagram. There's an electrical brake switch in that area that often breaks. There's also a little clip that's necessary for it to function properly. My switch was broken when I bought it with 15K miles. Cost about $35 to buy parts, 10 minutes to install.
Silicone lube worked !!!!
Thumbs up. Appreciate.
