Vance and Hines Side Shots
These are for '06+ Dynas with a 6spd. I modified the mounting bracket so I could mount them to my '04 with a 5 spd. The mounting bracket should still work with 6spd bikes, you'll just need to use fat washers since I more or less slotted the holes to to make it fit. They are in good condition, there are 1 or 2 blemishes at the very top of the heat shields from using an extension to tighten the stud nuts. Also included are the bung plugs for o2 sensors.
I want $200 plus the ride. They're still on the bike which is currently 500 miles away at my house. I'll be home this weekend so if you want them, i'll take them off and get them in the mail first think Friday afternoon.
I would agree USPS will probably be the cheapest. I'm not right in front of the pipes right now so it's hard to give you an accurate dimension. You should be able to go on Vance & Hines website and get a dimension. I will say they are heavy. It's a 2-2 with a welded crossover in the middle.
