None 103-110, s&s 585 cams, s&s 89cc heads w/.030 gaskets
Received 2,189 Likes
2012 FXDWG: 103-110, s&s 585 cams, s&s 89cc heads w/.030 gaskets
Dyno'd by Tallahassee HD
1745 Capital Cir NW, Tallahassee, FL 32303
http://www.tallahasseeharley.com/
issues that need to be addressed in circles:
It's always a good idea to plot the clutch slip by using gear ratio.
That way you can identify and quantify the slip.
For example, the big circle is possibly a lean spot in the cal causing a reduction in power whereas the other circle is clutch slip for sure.
Gear ratio compares wheel speed with engine speed. So a dip in power (big circle) graph is not usually slip as with the screwy graph (small circle) indication a lost relationship between wheel and engine rpms.
Bob
Bob
