Accessory fuse after LED light upgrade
Old 03-18-2017, 10:35 PM
14GuineaPig's Avatar
14GuineaPig
14GuineaPig is offline
" There was an unused wire with a 1/4" female push on connector "
Was this wire Orange/White Stripe? It's used on HDI models for a "Position" light and is on the ACC circuit.
inhershey (03-18-2017)
Old 03-18-2017, 11:30 PM
inhershey's Avatar
inhershey
inhershey is offline
There were actually 2 wires and yeah, one was orange. In fact that's the one that looked like it had been pinched and the insulation was flat and thin.
Old 04-20-2017, 07:38 PM
inhershey's Avatar
inhershey
I've had no more issues since insulating the two connectors and one wire that appeared smashed in the headlight housing. I think we can consider this one solved.
I do by the way really like the LED headlight and the LED aux light's are even more incredible. I'm not sure but I suspect they may be a bit painful foroncoming traffic.
Old 07-24-2017, 11:53 PM
Flyndutchman's Avatar
Flyndutchman
Flyndutchman is offline
wrong led in the turn signal you have to get the right one. Check to see if the socket matches the bulb. Some have two connectors and some have one. You might want to compare the new with the old. Just a thought.
Stephen Chapman
05-23-2015 06:06 PM
UltraClassicElectraGlide
08-19-2013 04:04 PM
Stape
06-13-2012 04:30 AM
cmose
03-24-2012 03:40 PM
harley9607
04-10-2008 10:33 AM
Quick Reply: Accessory fuse after LED light upgrade
